nitrous trouble shooting
Old Mar 11, 2006 | 01:55 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
whats up, i finally got my nitrous hooked up, and when i turn the switch on to arm it, the light comes on as if it has power to the system, but it doesnt work., im running a nx wet shot, i have it to a wot switch and a window switch, is it possible that one of them is bad? i even pulled the nozzle out of the intake and held the car at 3500 rpms and pressed the WOT switch manually with the system armed to see if anything sprays out..which it didnt. Im lost to as what could be the promblem other than a bad switch, maybe the relay?? how can i trouble shoot that? i dont know anyone have any ideas? thanks in adance
Brandon
Old Mar 11, 2006 | 12:48 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
It would help if you could post up a diagram of how you have everything wired together.
You'll get it
-Schultzy
Old Mar 11, 2006 | 02:45 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
try putting the hot wire off the solenoids directly onto the battery to verify that they click open. If they do then you need to go over your wiring again and triple check to make sure everything is wired correctly per NX's diagram... Electronics can be a PITA..
Old Mar 13, 2006 | 02:27 AM
Car: 91 z28
yeah i did what you suggested, the damn WOT switch was no good but i got it all fixed now, the grand prix layed down a 14.3@95.1 with a 2.1 60 ft woot!
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Lmancha96
Sep 25, 2015 08:11 PM
