Nitrous and a mechanical fuell pump...?
Old Sep 17, 2000 | 07:27 AM
Biochem's Avatar
Car: 2002 SOM z28
In the plans are a Holley DP (maybe 700cfm) and a Carter 120gph mechanical fuel pump to replace my ecm-Q-jet and stock pump. I hope to run a wet system and a 100-150 shot. I plan on a window switch too. Sound OK?
My question is about the mechanical fuel pump. Usually I see in magazines when they install a king-sized nitrous system, they always have an electrical fuel pump and plumb some fuel to go in with the nitrous. I really don't want to install an electrical fuel pump/ regulator... What are my options? Is running a mechanical pump fine?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Sep 17, 2000 | 04:01 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Running 150 HP shot of spray off the mechanical fuel fuel pump is fine.If you were going any higher than that I would put in a electric fuel pump just for the NOS.
Superman
Rev'n to Seven
Old Sep 18, 2000 | 04:54 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i went with an electric pump because my mechanical didn't flow evenly,surged alot.i would suggest afuel pressure switch to disengage the nos if fuel pressure drops below #5.
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Old Sep 19, 2000 | 08:54 AM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
craig is right. Buy an elect. fuel pressure gauge (Stewart Warner) and make a few runs and see what your fuel pressure is before you even install the NOS kit. Waite a min. i know what it will be: 1 to 2#. Not enough. You will need at least 4 to 5# fuel pump pressure at W.O.T. So then you go out and buy a Carter HP pump (8#) but then you have driveabilty problems. Eng. runs rich, bad fuel milage ect.ect. The right way is to install a seprate fuel system for the NOS. This is a major job, drop fuel tank ect. ect.,so i mounted a Holly red pump by the fuel tank and run it in conjuction with the stock chev pump. I drew up a complete diagram for this syestem and if anyone needs one let me know.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
