Supercharged SuperRam or HFLTR
Old Nov 18, 2000 | 08:33 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I'm currently using the superram upper intake and base manifold with 1000CFM throttle body. I am wondering if I use high flow long tube runners with stock ported plenum, if I will lose any peak or high RPM horsepower. I know I will gain low end torque, but at what cost of upper end horsepower and torque?
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
Old Nov 18, 2000 | 11:01 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
You will lose some power above 5000 RPMs or so, but it won't be as dramatic a loss as it would be on a naturally asperated motor. The bad news is that the increase of torque from long runners won't be as dramatic on a force fed motor either.
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Pac J
May 17, 2020 10:44 AM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
