what is your prefered bottle heater?
Old Apr 18, 2001 | 12:10 AM
Kandied91z's Avatar
i'm torn between nos and nx, i have an nos system; but heard nx makes a better heater any suggestions.......... thanks in advance
Old Apr 18, 2001 | 02:13 PM
Bob Wooten's Avatar
I was just checking into them & it appears that the new NX units that control bottle pressure & not bottle temp are the way to go. after all the plan is to heat the bottle until you get the pressure to a set point & to keep it @ that point. when it changes is when you run into problems.
Frankly I am surprised that someone has not dont this earlier (maybe they have & i have not had that channel plumbed into my cave). this is so simple & elementary to the principle of NOS, that it is one of those Duuuuuuuuuuuuuh moments.
NX all the way, if you ask me. if the car hangs together this weekend (I am going to the track), I think that i am going to call them up & order some solenoids, heater, purge valve & build a system.
BW
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Apr 19, 2001 | 12:28 AM
Kandied91z's Avatar
sounds great bob, and frankly i agree with you but i had to purchase the nos; simply for cost $100 difference to be exact......i don't race that much so it just seems a bit much for the nx
Old Apr 19, 2001 | 10:35 AM
SpRaYd91Z28's Avatar
You get what you pay for...NOS heater system is usless as far as the temp gauge goes....what happens with the volume of NOS goes down? Do you think a smaller amount of fluid will get to the same PSI at the same TEMP? NO!!!!!!!!! The NX system, reguardless of volume of NOS inside, will bring the bottle to an optimum 950psi for perfect mixture... =) It's worth the money when it comes down to performance! The NOS is just as good as a heater blanket for 29.99 at wal-mart.
Zach
1991 Z28, Black ext. Grey leather interior.
-Engine/exahust Mods:
-=MSD 6A Ignition/MSD Blaster Coil
-=Flowmaster/no cat
-=Headers
-=Air foil.
-=Superchip.
-Drivetrain:
-=2k Stall
-=1LE Aluminum Driveshaft
-=Customer Shift Kit.
-Free Mods:
-=TB Coolant
-=Modified air box
-=Removed Smog Pump (shorter belt).
-==Best Motor E.T. 13.59@102==-
Old Apr 19, 2001 | 12:33 PM
Bob Wooten's Avatar
You are right, but some heat is better than no heat, "IF", bottle temp is the issue. if there is something wrong with the system, this is all for not.
My2c.
BW
Bob Wooten
71 Camaro, 91 EFI
Old Apr 19, 2001 | 05:03 PM
Kandied91z's Avatar
good point bob, i'm using this just to make sure my system is all right........eventually if it the system works right i will get the nx; but saving 100 to check your system sounded good to me.
thanks everyone for the help
FueledSoul
Sep 29, 2015 08:43 PM
dusterbd
Sep 29, 2015 08:40 AM
