upper radiatior hose probs!!!
Old May 14, 2001 | 09:36 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
hey I keep cutting the hose with the upper metal pulley on the super charger bracket thats for the engine belt not the super charger belt, has anyone else had this prob and what do you do about it? other than zip tie the hose up to the intake tube?
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. So if anyone knows where a buick GN 8.5" rear is let me know.
Old May 14, 2001 | 09:38 PM
Jester's Avatar
put a section of steel tubing in the hose in the section that rubs.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 14, 2001 | 09:42 PM
monte-ss's Avatar
and then Ill get to see sparks now??
Old May 14, 2001 | 11:33 PM
89GTA5spd's Avatar
On the paxton i'm selling there is a bracket that goes over that pulley that probably stops what you are talking about.
it looks like this:
<--3"---->
_________|
and is 3" high as well. there is a notch cut out to attatch it to the pulley mouting bolt behind the bracket.
perhaps you can make a similar part to stop the hose from rubbing... are you using the new hose paxton supplies with the kit?
Old May 16, 2001 | 12:24 AM
monte-ss's Avatar
thanks 89 I figured it had to be something like that, I had a big chunk of a 3" aluminized exhaust pipe. its what I used for my intake system, cut a piece of that in half and drilled a hole in it, looks pretty decent and works awesome.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
