supercharged cranckshaft question
Old May 16, 2001 | 11:08 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
My engine is being done right now.When I told my machine shop I was supercharging he told my something about needed to have a extra bolthole drilled on my crank or the pulley of the SC would tearup the crank.He was saying something about a keyhole orthree way key, something like that.Has anybody heard of this?Thanks
89 formula 350, 73000k, 9-bolt 3.27, gutted MAF,dynomax muffler,gutted air box,kn,accel 8.8 coil wires,dunlop 60/235
g-tech best(9 runs)14.48@101.1 0-60=5.91
track best(3 runs muncie,in 88 degrees)14.51@96.0 60' 2.089
in the garage waiting to go in are alum. L98 heads(bowl job by scoggins-dickey),ported high-flo edelbrock base,SLP runners, Jethot coated SLP 1 5/8 headers,zz3 cam 208/221 .474/510,1LE alum. driveshaft,TCI 2200 stall,LPE feul reg.,TPIS air foil,Flowmaster ForceII cat back,Gold crane 1.5 rollers,Eagle forged 5.7 rods,TRW Speed-Pro forged -21cc dish pistons,MSD 6A,8.5 wires,BlasterII coil,lots of ARP bolts,
Old May 17, 2001 | 01:19 AM
Bob Wooten's Avatar
Yes, the pully that runs the belt has a key way to keep the pully from sliping on the crank. if you are putting a blower on it, there is the chance that you are going to shear the key off. this happens more on Roots style blowers that put a larger load on the crank than the centrifugals do. for large boost apps, this is a good idea, but i bet that there are a bunch of guys here on list that are running good amounts of boost that do not have second or third keys.
Old May 17, 2001 | 06:44 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
iv been running my blower for three years
and run the max boost i can and never had
a key strip on me.
check out my simple page at:
Http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old May 18, 2001 | 08:48 PM
L98FORM89's Avatar
Engine: 355 HSR
Is the key part of the crank or the pulley?What happens if the key strips? Will it cause less damage if the blower is self-contained like the Procharger? Thanks again!
Old May 19, 2001 | 01:58 AM
Bobalos's Avatar
The one that I saw first hand sheered the key right off flush with the crank. if you can imagine 1/2 the key was in the groove in the crank & 1/2 the key was in the groove in the Ballancer. knowing how hard it is to get a ballance off when the key is good imagine trying to get one off w/the key sheared off & little pieces of key stuck inbtween the shaft & the ballancer. it is a royal pain in the rear.
But as DARCOM said, there are a LOT of guys out there that dont see this, 'specially with the centrifugals. it is when you run large boost 6-61's & 8-71's (& i suppose large centrifugals as well) that they put a large load on the pulley to turn. if you have ever tried to turn a blower by hand you know what this is like. now try to spin it under pressure & @ 6000 rpm. this is LOAD.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old May 19, 2001 | 02:02 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i supose if the key did strip it would mean
that your motor would run but your accesserys
would not turn or turn slowy and would
eventuly were out the snout on the end of the
crank.
the key is a peace of hightencle steel thats
shaped like a half circle and fits in a slot
between the crankshat and harmonic balancer.
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
