How much HP can the 5L TPI handle?
Old May 6, 2006 | 01:08 PM
Speed_Kills's Avatar
Been looking at the stage 2 intercooled D1SC Procharger kit. I was going to do heads but i can always do that later. How much power can the 5L handle? Will running 10 Psi be pushing the stock bottom end?
Old May 6, 2006 | 03:28 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I think 10psi will be fairly safe on the stock bottom end with a good tune. I would consider the pistons as the weak link, as the cast pistons can break if they are exposed to detonation. I'm a big advocate of seeing how far the stock stuff can go. Some people like to build everything right away, which is fine if you have the money. But a 305 isn't worht anything, so why not push it until it breaks? I bet you could run 10psi for a long time before it gives you trouble as long as you watch your AFRs and keep and open ear for detonation. Premium fuel and colder plugs will be a must.
Old May 6, 2006 | 04:13 PM
Thanks 89,
Your setup sounds like a beast.
AussiePr0nCar
Mar 6, 2020 04:04 PM
kairles
Oct 26, 2015 09:13 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
