Paxton rebuilds?
Old Jun 13, 2001 | 06:33 PM
craiger's Avatar
Paxton rebuilds?
I have had nothing but good results with my paxton SN 2000 m. However, hearing all of the problems with the ball drive uints, i was wondering where i could get mine serviced and how much it cost? I have 8K miles on my paxton, I change the oil every 3mo which is usually about 1500 miles. I have had no complaints except the tech dept!!!!!!!!! ! Anyhow, Where can i get the unit rebuilt when needed and How often do i need to get it repaired?
Old Jun 14, 2001 | 05:26 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Paxton probably still services the SN2000 models themselves. The older units like sn92s are referred to Paradise Wheels for service. They may also service the newer ones as well, I don't know though. You can see more at https://www.thirdgen.org/messgboard/...ML/000531.html
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Jun 14, 2001 | 06:28 PM
BLOWN85/TA's Avatar
Forget about Paxton and go straight to Paradise Wheels and talk to craig.
Old Jun 15, 2001 | 03:48 AM
Forced_GTA's Avatar
I thought my SN2000 was going to go today (less than 1K on it) cause I started hearing this horrible whining at idle. So I drive home (about 4 miles), pull off the S/C head unit and start the car w/o it. The car still whines, i guess it is the p/s or alternator (can't build up charge, so maybe alt). I listened for it w/ a hose, but couldn't 100% pinpoint it. Before the paxton i didn't mind changing the alt, but know if is a f-cking pain! I hate the SN2000, always worried it will break on me! Maybe i should start saving up for a vortech/ati.. or just an LT1 car.
Old Jun 15, 2001 | 09:07 AM
craiger's Avatar
First thing you should do is release the tension on the supercharger belt, then if the whinning stops....you may have a problem However, an altenator can make similar noise as you have described.
Old Jun 18, 2001 | 08:17 PM
Forced_GTA's Avatar
It was the alternator. The main ground cable was literally touching the big output cable from the alternator and arcing i guess. I moved the ground and replaced the alternator and it seems fine now... go figure.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
