Changing the oil in a SN92?
Old Jun 21, 2001 | 10:00 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Should I just turn it upside down or what to get the oil out? And how much should I add back in? Would you guys recommend Trick Shift?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Thermomaster chip/160 degree thermostat
gutted airboxes/K&N filters
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Old Jun 22, 2001 | 06:49 AM
89GTA5spd's Avatar
When I had my SN, I would either turn it over and drain it (but turn it over several times and at different angles to get more fluid) or as some one on this board pointed out, you can change the fluid with the unit on the car with a windex (or whatever) spray top with the pickup tube placed into the dipstick hole and spraying the paxton fluid into a container. That is very useful since if you are at the track all day you probably want to change the fluid at least once. Trick shift worked great for me. The only place I could find it was Autozone for $3.99.
Old Jun 22, 2001 | 02:38 PM
Bobalos's Avatar
Paxton recommended thier tool, which was as he discribed it, "a turkey baster with a longer tube on the end to get down into the bottom of the blower".
We can get trick shift @ Pep Boys here in So Cal.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old Jun 23, 2001 | 01:54 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Yep, go to the grociery store, or raid your wifes, or your moms kitchen and get a turkey baster. Then take it with you to the auto parts store and buy some steel brake tubing that will fit tightly up into the nozzle of the turkey squirter. You probably will need to cut the flared end off of the end of the tubing. stick it in the baster and secure it with a nylon wire tie or two. Cut the tube to the desired length and then you will have a genuine artificial Paxton oil change device for about $200.00 cheaper than what they probably charge for it.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
maroe624
Apr 16, 2017 08:29 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:52 PM
