direct port nitrous
Old Jun 26, 2001 | 04:41 PM
TexasLT1's Avatar
Car: '92 RS
direct port nitrous
ok, I saw a picture of a sweet direct port nitrous set-up the other day where all of the injectors were hidden under the plenum and the supply lines ran out the back. is this a custom job or does someone make a kit to do this? I can see how it would not be too hard to simply drill and tap the runners and screw in the nitrous injectors, but is that how it is done? just curious, something to look forward to down the road
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
Old Jun 27, 2001 | 02:57 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I don't know if they still make it or not, but NOS used to make a kit for an under the inake manifold, direct port set up. If they still make it you could probably install it in the manifold, runners or plenum.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Jun 27, 2001 | 12:36 PM
Bobalos's Avatar
A buddy of mine tried to install it into his Carb manifold & ended up destroying the manifold. with the manifold that he had, he had to put the injector nozzles right up towards the edge of the runner & it cracked the aluminum. He bought another manifold & took it up to NOS (when they were here in So Cal) & they did it for him (for a few $$$). It worked OK, until he ran the motor out of oil & bend a con rod. It is not worth the Pain if you ask me.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old Jun 28, 2001 | 12:35 PM
TexasLT1's Avatar
Car: '92 RS
actually, I would be doing it during a buildup anyway so the manifold, plenum, and runners would already be apart
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
