N2O Timing question
Old Jul 18, 2001 | 10:56 AM
mefreema's Avatar
N2O Timing question
I am setting up my nitrous system. I have an adjustable carb plate kit from 50 to 100. It recommend to pull 2 degrees of timing out for every 50hp. I am setting up a seperate fuel cell with 110 octane gas for the fuel solinoid. The carb will be fed through the normal gas tank which I run 93 octane. Since I am spraying with 110 octane can I get away with removeing less timing. Maybe like 1 degree per 50 hp. Thoughts & sugggestion appreciated! Thanks.
Old Jul 19, 2001 | 01:26 PM
mefreema's Avatar
Anyone? Anyone?
Old Jul 19, 2001 | 05:14 PM
Cosmik Debris's Avatar
If your mixture is correct you won't have to pull any timing for a 100 shot.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
