which fuel pump to use for ~600 rwhp?
Old Aug 8, 2001 | 08:33 PM
Twin Turbo 358's Avatar
ok, i need to get a fuel pump soon for the GTA TT. which pump should i get? i am only going to run 1 pump (external). i have a sumped gas tank, -8 fuel lines up to the rail, 83 lb injectors, Accel DFI w/ variable injector controller, and will probably be making a conservative 600 rwhp. any suggestions? i was considering an SX pump. the Weldon will be overkill and out of the question (says my wallet). this is a street/strip car.
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old Aug 8, 2001 | 08:58 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I would recommend the Aeromotive pump. It is reliable enough to use in a regularily driven street car and will support 1000 Hp at 45 psi line pressure. That's what I am using on my car. The price is decent too.
Old Aug 8, 2001 | 10:26 PM
thanks--i will check into that one... any suggestions on a vendor?
Jeff
99 T/A WS6 A4, 12.97 @ 105, lid, cutout, free EGR mod, Yank Stealth
Old Aug 9, 2001 | 12:21 AM
89ProchargedROC's Avatar
Aeromotive are made by the same people as the paxton pumps
i wouldn't use them personally. Spend the money *ONCE* on a Weldon and you wont ever need another pump PERIOD.
BUT, if you cant afford it...i'd look into the SX line
Old Aug 9, 2001 | 07:15 AM
Guido's Avatar
Car: 2000 Trans Am
I bought an aeromotive but I got a hell of a deal on it and a bunch of other braided line and fittings.
I would have liked to have a weldon but for the price I couldnt turn down the deal I got. I have not had a problem at all. Although if you look on camaroz28.com some people have had them fail on them. That could be figured up to improper use but there are a lot of people using these pumps now.
I think I am only using about 50% of the pumps capacity right now.
-86 IROC
11.31 @ 120.2 mph
-=ICON Motorsports=-
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
92camaroJoe
Aug 13, 2015 06:07 AM
