Anyone with a vortech......??
Old Aug 10, 2001 | 12:03 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm installing a vortech on my buddies 88 GTA this week and we are installing an AFPR, shorty headers, and runners at the same time....my stupid question of the day is this:
What do you run your fuel pressure at??
I haven't looked under the TPI in a while, can I set it running or do you set it with the engine off, key on.?
Thanks in advance.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 10, 2001 | 07:15 AM
Guido's Avatar
Car: 2000 Trans Am
If you set your fuel pressure around 45-48 psi or so, the FMU should take care of the rest.
EDIT:
You can set the pressure with the car running but you will have to remove the vacuum line that runs to the regulator. This will throw your pressure setting off a hair but if you verify pressure WITH THE VACUUM LINE ON then you should be fine.
Good luck!
-86 IROC
11.31 @ 120.2 mph
-=ICON Motorsports=-
[This message has been edited by Guido (edited August 10, 2001).]
Old Aug 10, 2001 | 07:32 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Aug 14, 2001 | 12:33 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
remove it and plug the line
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best ET (Nat. Asp.): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 -*100% NYS emissions legal*
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, Install completed 7/9/01: 10 & 15 LB. PULLEYS, HKS race bypass, Custom cold air, Swapped to serpentine. Best ET: High 11'S I Hope.
[This message has been edited by Justin 87 GTA (edited August 13, 2001).]
