Supercharger for a 87 MAF IROC?!!
Car: 87 IROC Z28
Transmission: TH700R4
Is it possible to get a supercharger for my car?! Dont think the MAF wire can handle it... help!! Thanks
Ant
87 IROC 305 TPI
Compucam 2032
SLP 3" cat back
Gutted Cat
Custom PVC Cold Air/Ram Air
Gutted Maf
TB coolant Bypass
Ported Plenum
Accell Coil/Cap/Rotor
Bosch +4 Platinum
Richmond 3.73's
700R4 Trans-Go shift kit
Crane AFPR
Performance Resource Chip
Ant
87 IROC 305 TPI
Compucam 2032
SLP 3" cat back
Gutted Cat
Gutted Maf
TB coolant Bypass
Ported Plenum
Bosch +4 Platinum
Richmond 3.73's
Crane AFPR
Yes you can use the MAF with the supercharger, unfortunately Paxton is the only system available as a direct bolt-on for your car, if you change to a serpentine belt system you could open up your options to a ATI Procharger or Vortech Supercharger
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Car: 1987 Z28 Convertible
Transmission: 5-speed
Paxton:
<IMG SRC ="http://wsphotofews.excite.com/032/ba/ic/Nt/eq98373.jpg">
Removed Paxton, retired the v-belt system, installed a serpentine system, then added a D1SC ProCharger with three-core intercooler:
<IMG SRC ="http://wsphotofews.excite.com/027/H2/1G/Ow/hL68299.jpg">
Same car, same engine, different blower only.
I don't think the MAF wire can handle it... help!!
Why not? My handles 12-flat runs at 117 mph!!
Willie
[This message has been edited by Willie (edited August 21, 2001).]
Paxton:
Willie
toronto formula
Nov 10, 2015 06:17 AM
mustangman65_79
Aug 11, 2015 03:17 PM
