N2O and manual tranny...
Old Oct 13, 2001 | 02:51 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
When is it safe to hit the nos button when your shifting?
Do you have to be in 5th gear wide open?
Can I use it sooner like in 3rd, and if I do what happens when the nitrous is flowing and I change gears to fourth. I thought you have to have it wide open at all times when the nitrous is flowing?
Dave
Old Oct 14, 2001 | 03:15 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
You can use nitrous in any gear. If you wait until you are in 5th You probably have already lost.
Yes you should be at wide open throttle when using it.
You can use a manually operated normaly open switch on the gear shift. You can release the button while shifting...
and/or you can use a normaly open full throttle switch to activate the system only when the throttle is fully depressed...
and/or you can use a normaly closed switch on the clutch pedal to disengage the nitrous when the clutch pedal is depressed.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Oct 14, 2001 | 05:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by IROCKZ4me:
</font>
"And" being greatly preferred to "or" when it comes to nitrous safety switches, of course.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
