As my next semi-low-budget mod to my car, im lookin into getting a performance chip. What chip should I go for, and with the said chip, what kind of power gain or other features should I expect to get from it? Are they as simple to install as just "plugging them in"?
305IrocZ28- Al
1990 Iroc-Z
305 TPI
0-60 in 6.8 (timed)
2.73 Posi (3.42 or 3.73 to come)
Flowmaster exhaust
T-tops
Red w/ black racing stripes
Pioneer headunit, stock speakers, Rockford 10'' punch woofers
Ricers beware...I eat you three meals a day
And the Camaro said to the Civic "Now, I know what you're thinking...in all of that mess, did he have 8 cylinders, or only 6? You just gotta ask yourself one question...do you feel lucky? Well do ya....punk???
305IrocZ28- Al
1990 Iroc-Z
305 TPI
0-60 in 6.8 (timed)
Flowmaster exhaust
T-tops
Some people think it's a waste of time. Depends on your mods. Out of a generic chip you might only see 5 HP...
With a custom chip, tuned to your specifications, though, you can see a LOT of power...an Ed Wright fastchip sounds good... www.fastchip.com
He also makes generic chips for our cars, and from what I'm told they're the best out of the bunch...that or maybe a JET Stage II....stay away from Hypertech.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Performance mods
Audio
Other
with relatively no mods on your vehicle a chip is what you think it's worth.spend the money to burn your own,you can practice with your current setup until you get proficient at it.then tune when you get into the bigger mods.iif you are comitted to a chp ed wriight is the way to go but he's expensive!!!!!!!!!!!!!!!!!!!!!
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
