350 build-up suggestion
Old Oct 25, 2001 | 12:57 AM
Paul_Ishmyknob's Avatar
Car: 1985 Trans Am
Engine: 305(LG4)
I plan to build a pontiac 350 carb setup soon, to put in a 1985 T/A. I was just wonderin if any of you had some suggestions for mods/engines. Such as good combos and what not that you have found from building burly panchos.
Thanx in a advance.
Peace,
-Curt
Old Oct 25, 2001 | 03:03 AM
Bandit TA's Avatar
Don't bother with a pontiac 350, there a weak motor and you'll have very little luck finding aftermarket parts for it
My suggestion, go with a chevy 350, no problem modding that what so ever
Old Oct 25, 2001 | 07:23 AM
Blockhead's Avatar
What a gay name.
Wrong forum too.
Try general engine ya goon!
Yea .... but it's gonna to the big adios in a BLAZE a glory....
Director of Darwin Awards @ www.thirdgen.org
Old Oct 26, 2001 | 03:48 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I agree with Bandit about the Chevy block. It probably won't be necessary, but try to get a 4 bolt main and a one piece rear seal. Most pickups from 87 up have that design.
If you have any questions just drop me an email. Its a pretty simple swap. if you have a TBI or TPI car now then you need to switch the fuel pump and I think the fuel lines too to go to a carb.
Mine isn't carbed out yet, but I can help with everything else...
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
