can it be done?
Old Nov 4, 2001 | 02:46 PM
Dauntless's Avatar
can it be done?
twin turbo on a carbed engine? I haven't seen any kits for it. can anybody point me in the right direction, if it can be done at all?
1984 Z-28, 305HO 4bbl, t-tops, K&N, Flowmaster 80 Series with 3" tips. Planning a massive modfest. It's gonna be one gangsta of a street demon.
Old Nov 5, 2001 | 07:09 PM
SoCo80p's Avatar
it can be done and i have seen it on a SBC and heard but never seen one a 455 buick. also saw a mopar on my classic car, basiclly EVERYTHING will need to be custom and cost in the 10K plus range for everything, but will get the car in the 8-1,000 HP area pretty easy.
Old Nov 5, 2001 | 07:11 PM
SoCo80p's Avatar
if you want to low buck it, find a 80-81 trans am or formula, some of them had factory 301 turbo carbed engines, you could build one of those alot cheaper then a custom unit.
Old Nov 5, 2001 | 09:50 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Unless you want to build the 301 (an expensive proposition itself) you don't want the Poncho turbo - it will only bolt to a Pontiac motor, and the intake, etc... is specific to the short-deck 265-301.
Instead, if you're interested in building a budget twin turbo car, take a long look here: <A HREF="http://www.geocities.com/MotorCity/Downs/8668/BudgetTT.htm">http://www.geocities.com/MotorCity/Downs/8668/BudgetTT.htm</A>
Old May 24, 2002 | 10:00 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Gale Banks did in in 1983 or 1984.
TTTA with 600 ponies going 200 mph.
Old May 25, 2002 | 07:32 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
For what its worth, Mike's site is now at www.toohighpsi.com.
Old May 25, 2002 | 01:03 PM
89 Iroc's Avatar
Jester is building a low buck carbed TT motor maybe he can give you some advice. He's a moderator on the carb board.
