? about digital dash when puting on vortech supercharger
Old Nov 10, 2001 | 03:17 AM
c350b's Avatar
ok, i have a 88 gta with the digital dash, and it has a system check and if a door is open or a light is out it will tell you, it will also tell you when you are low on washer fluid when i install my vortech i get a whol new washer fluid reservoir wont it think i'm out of fluid on the dash, what can i do to fix that
thanx
c
Old Nov 10, 2001 | 08:56 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I'm not familiar with the sensor used on the GTAs washer fliud reservoir but most use a simple electric sensor mounted through a hole in the side of the reservoir. If yours is that way and the Vortech kit requires replacing the reservoir then You can probably use a hole saw to cut a hole in the side of the new reservoir and mount you sensor there.
sheachopper
Jul 31, 2019 11:27 AM
Lbibb
May 5, 2016 12:00 AM
anesthes
Sep 30, 2015 07:48 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
