Yet another Junk Yard Turbo Question...
Old Nov 17, 2001 | 01:48 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Ok, so there's a Single turbo first gen Toyota Supra in the local Junk Yard, how well would this suit my LG4 305? It'd only cost me $40... how well do these fare when just sitting around?
The Supra engine: 3.0L DOHC I6
I wonder what happened to it, the car is in great shape, just seems like a waste.
1984 Firebird - Daily driver, 305 LG4, 3.23 rear, T5 - Hurst short shifter, Edelbrock 600 CFM 1406 carb, Performer intake - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 5 Spoke Wheels, AIWA bargain basement (from Sears of course) CD player, Eight-ball shift ****
Check out my ride here
"IT'S SNOWING! TO THE HIGH SCHOOL PARKING LOT!" - The Mustang and Firebird face off in the dead of winter.
Old Nov 17, 2001 | 08:38 AM
scauffiel's Avatar
Well, it's only $40 - go get it and then read your rear end off about turbocharging. If you determine that you can't use it you can always e-Bay it. Or you can try to pick up another and twin turbo it.
Just my $.02,
Steve
Steve's Trans Am Temple
Old Nov 17, 2001 | 09:23 AM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
The turbo was about 8-10 inches in diameter... it probably gives a pretty hefty boost. What is the likelyhood that a turbo would sieze up after sitting in a junk yard?
This car has been there for a good 2 months at least.
Old Nov 17, 2001 | 11:35 AM
Jester's Avatar
I havn't the slightest clue what would be in a first gen Supra. It might not even be stock. But, 8-10" is a fairly decently sized turbo, probably big enough. I'd go grab it and then look it up. If it turns out too small..you're only out $40.
Assuming no water got poured into the turbo and left there for some reason it should be fine. Reach in and see if the turbine still spins. If it does, and doesn't slop around enough that the blades hit the housing, it's probably at least rebuildable.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Nov 17, 2001 | 07:38 PM
JAY87GTA's Avatar
Also look inside at the impellar to make sure there is no damage. Any sort of thing can do alot of damage to a turbo. If it is still under the hood or otherwise covered then snag it, it's only 40 bucks. Should be worth about 6 psi anyhow.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
armybyrd
Sep 26, 2015 03:37 PM
