what cc heads-afr should i get
Old Nov 16, 2001 | 08:40 PM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
going to purchase afr 190 aluminum heads for my bird.it has a stock lower end and a modified intake with all the bolt on's-asm runners edelbrock base,ported plenum--running slp 1-3/4 headers also 6 PSI boost-i'm thinking that with the aluminum i can increase compression. so the afr's come at 68 cc,the stock iron heads are 64cc(so i would loose compression) and vettes aluminum heads are 58cc .so should i have them milled to 58 as i know many people are running 6 psi on vetts with no problem.i've also read that vette's hawe the same compression as the iron head l98's even with the smaller cc heads because of a thicker head gasket but don't know if this is bull or not
thanks
350 tpi,paxton sc,slp exaust@headers
[This message has been edited by icecold (edited November 18, 2001).]
Old Nov 17, 2001 | 04:59 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I got 68cc AFRs for my as-yet unassembled 355 Vortech S-trim combo. I wanted to maintain a reasonable compression ratio since I'm not going to be intercooled (at least not at first... $$$)
Old Nov 18, 2001 | 07:42 PM
icecold's Avatar
Car: 1990 formula
seems that i should have them milled to 58cc like the vettes--anyone else running 10-1 comp with low boost(5-6 psi)?
Old Nov 19, 2001 | 12:21 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
LT1 guys run that, if I'm not mistaken, and do allright. If you're not going intercooled, make sure you have boost retard with that combo.
63bravo!!
Aug 1, 2010 05:45 PM
