N2O -VS- 140,000 mile
Old Nov 20, 2001 | 01:35 PM
berlinetta85's Avatar
I was wondering if a 100 shot of nitrous would tear up my 140,000 mile 350 power plant? The motor runs strong and I just redid the tranny. It pulls like no tomorrow, but I need that added edge. The ignition system is new with plugs, wires, and cap & rotor. Could use the advice, thanks.
Old Nov 20, 2001 | 02:48 PM
chevyboy07 91's Avatar
if it were me personally....I'd go for it in a heartbeat. A 100 shot is very mild. It will definetly give you that added edge you are looknig for.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Nov 20, 2001 | 03:02 PM
SoCo80p's Avatar
i think a 100 shot should be allright for a here and there boost, but i wouldnt use it all the time,.
Old Nov 20, 2001 | 03:23 PM
Fastcamaro87's Avatar
do a compression check , if everything checks out okay you should be fine.
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
No Cat, Dynomax Headers & catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims.
406 siamesed TPI in progress
Old Nov 22, 2001 | 07:56 PM
20-psi's Avatar
I've used a 200 shot on my 5.0 motor with 190K miles on it for the past two years and havn't melted anything yet.
Pete
(10.97 @123 mph)
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
GouldyGTR
Sep 7, 2015 09:05 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
