Supercharger or Turbocharger
Old Nov 25, 2001 | 12:34 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I know that they do not make a Turbo kit for thirdgens yet but I was wondering when they come out with a turbo kit, which would give more power? A turbo or a supercharger?
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported & Polished Plenum
-- Blue LED Bakelite Dash & Climate Control
- I am just some 17 Year old spending every dollar I make on my car.
Old Nov 25, 2001 | 01:24 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Turbocharger, because if everything else is the same, you won't have the 50-100 hp loss needed to spin the blower. The increase in exhaust backpressure does cause some HP loss, but that's only 1/4 of the engine cycle, and not much compared to the energy you get from it. Hope this helps!
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
Old Nov 25, 2001 | 02:12 PM
skipsZ28's Avatar
Car: 85 Iroc
Engine: 385"
a turbo takes away 0-5 hp for every 100 hp it produces. supercharger takes away around 30 hp for every 100 hp it makes. a turbo would be better in my mind, if you have the funds.
Old Nov 25, 2001 | 03:49 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Two identical engines with the same boost, one with supercharger and one with turbo.
The turbo engine will have less effective boost (intake pressure - exhaust pressure) and it will therefore flow less and have less crank hp.
The supercharger will rob some hp from the crank and reduce the hp reaching the wheels.
<font face="Verdana, Arial" size="2">a turbo takes away 0-5 hp for every 100 hp it produces. supercharger takes away around 30 hp for every 100 hp it makes.
</font>
That is probably true with the old roots type blower, but the modern centrefugal superchargers are just as effective as a compressor in a turbo. The supercharger will lose some in the gearbox and the belt drive and the turbo has less rotating mass. I agree that the turbo setup is more effective, but the difference is not that big.
Why select a supercharter?
+ Easier installation, no need to change the stock exhaut.
+ Lower under hood temperatures, almost the same temp as a stock engine.
+ Easier fuel calibration, boost follows RPM, not engine load.
+ No turbo lag.
- Low boost at low RPM
- At high hp the belt can slip
- The supercharger has more parts that can fail. ( gearbox, pulleys, ball bearings )
Why select a turbo?
+ It is possible to get more hp
+ Few moving parts (only one)
+ Can have full boost at low RPM
- Turbo lag
- Must let the turbo cool down before shuting the engine off.
- Difficult exhaust plumbing.
- Very high under hood temperatures.
Jonas Bylund
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
BBSDesigns
Sep 22, 2015 03:08 PM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
