Problem w/ Dart block & AFR heads
Old Jun 5, 2006 | 08:12 PM
87IROC350's Avatar
Engine: 5.7
I'm assembling my oringed 377 and ran into and issue that the ICS Titan self sealing gaskets don't match up. The sealant bead for lower coolant hole towards the bottom between 2 & 4 and 6 & 8 runs below the bottom of my AFR 190 heads. Just great.
Any suggestions on the best method to seal these to prevent leaking coolant? Also the dart little M block is a 400 bore so does it also need the coolant holes drilled in the heads like the factory GM blocks?
Old Jun 6, 2006 | 10:53 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Odd. I've got the LittleM block, and AFR210 heads with no issues sealing. This is using the Felpro Locwire o-ring head gaskets. The magic goop I use to seal things that don't seal well is Permatex The Right Stuff - like Silicone RTV, but seals tough jobs better (although it's harder to clean off). I'd check w/ AFR & Tilton also. Maybe just swap to some different gaskets now, rather than chancing a fix w/ RTV.
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Jonas Earl
Sep 27, 2015 07:39 AM
