prob with boost vac guage, installed wrong ?
Old Jun 7, 2006 | 03:08 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
I put a mech. boost/vac guage on the car and started it up, it reads like 20lbs of boost at idle obviosly ive got something backwards, i used the copper install kit and t'd off some brass fittings ive used for vac directly on the back of my stealthram....what gives ? Would it be better to go with some rubber tubing and t into say my MSD BTM ? I should have vac on the guage at idle right ?
Thanks fellas !
Old Jun 7, 2006 | 03:14 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yes you should have vacuum, are you sure it's reading boost and not vacuum? could be a faulty gauge
Ghettobird52
Jul 5, 2024 11:18 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
