choices
Old Jul 30, 2006 | 02:00 AM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
choices
well i make it quick. (all this is on the way) I have a lt1 with ported heads and a cam and some stout internals but the top end is stonger than the bottom in my opinion, but it has been converted to carb, also i am running a B&M 700r4 with a 10 bolt dana 2 speed floating rear end which I have never heard of have yall? but should i put my tpi on it or leave it carbed??
also should i just run nos, or turbo maybe super charger, another can u turbo or supercharge a carb motor??
Old Jul 30, 2006 | 08:18 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
I would switch the LT1 back to fuel induction instead of carb. The TPI sistem will not work with the heads, and if it does somehow line up, the LT1 intake was made for that engine.
Yes you can turbo/SC a carb motor. There is a special intake that gets put ontop of the carb from the turbo/SC.
About the dana, your axle has 2 speeds???
Old Jul 30, 2006 | 01:20 PM
19Irocz86's Avatar
Engine: 305 tpi
I have never heard of it either but the guy said it was a 2 speed floating rear end.... with a B&M 700r4 and a carbed lt1 for 1100$ so im takin it
Old Jul 30, 2006 | 04:31 PM
vwdave's Avatar
If the guy is that big of a moron I wouldnt buy anything from him. No telling how much is bastardized it.
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
david068513
Sep 18, 2015 10:36 AM
ericjon262
Sep 11, 2015 06:07 PM
