juicing my GTA
Old Jul 30, 2006 | 08:12 PM
boosting28psi's Avatar
juicing my GTA
im throwing a 5151 kit on my TA and wanted to know what shot 100-150 to use...also when i get the kit do i need to get anything else? and what size are the throttle body bolts and how long do i need? if any
Old Jul 30, 2006 | 09:29 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Start small on the n2o shot and work your way up.
Get another fuel pump.
Window switch
rev limiter
as for the throttlebody bolts, I'm not sure, use the !!
Old Jul 30, 2006 | 10:05 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You should need nothing else with the kit, it should come with bolts and all. The only thing I could think of you needing is wiring and a momentary switch. If you get another fuel pump you'll have to lean up the fuel side of the nitrous kit (assuming it's a high volume pump) Call NOS they'll guide you through it.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
JSDaddy189
Sep 26, 2015 03:50 PM
