NITROUS HELP! Direct port or regular wetkit?
Old Aug 4, 2006 | 01:34 AM
ineeedmorespeed's Avatar
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
Ok...I'm looking at getting a nitrous kit for the vehicle shown in my sig. I'm looking at running no more than a 150 maybe 175 shot...preferrably starting at 75-100 shot.
I've got an offer on the table to purchase a "like-new" NOS-05151 kit complete w/o the bottle for $325 + S&H.
OR
I could purchase a direct-port nitrous kit "used" for $400 + S&H. I just want to know if this is something you nitrous guys would recommend...I'm worried something may go wrong with the direct-port kit. Here is what the seller wrote to me in e-mail:
"I'm including the runners(with all the nitrous nozzles
attached) the nitrous 10lb. bottle, all the fuel and
nitrous lines. All you will need to do is remove your
runners, and install the nitrous ones. Remember that
you will need to replace two of the nozzles first. You
can find them on ebay for a lot less than any
retailer. Just find a suitable place to mount the
bottle and run the lines and install all the switches
and you will be good to go. I installed this system on
my stock vette with no danger to my engine. You just
need to make sure the system works properly before
hitting the nitrous."
Does that seem like a pretty good deal for $400 or should I just go with the wetkit and buy the bottle seperate...spending about the same price??
Remember...I don't want to run more than a 150 maybe 175 shot. Is it even worth to go with the direct port...even though it would be the same price as the NOS wetkit?
Thanks in advance.
Old Aug 11, 2006 | 03:36 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
i run the single fogger nozzle wet kit myself pretty easy simple install and go play if ure only lookin for a 175 or less stay with a single fogger or plate set up get a complete kit dont hassle with a kit someone put together or partial unless u messed with nitrous before and no what ure dealing with good luck happy spraying, its addicting
Old Aug 11, 2006 | 07:24 PM
thanks...i think im goin with the nos-05151 kit...
2012sergen11
Oct 13, 2015 07:38 PM
327IROC85
Sep 23, 2015 12:11 AM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
