need help with paxton sn2000
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
My Paxton SN2000 seems to be blowing oil in my throttle body and intake. I removed the piping from the discharge on the supercharger and started the engine, and sure enough oil started to seep out. Has anyone had this happen? I am thinking there is a seal going bad.I would also like Paradise Wheels website if anyone has it. Thank you for any help.
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Their website is www.paradisewheelsinc.com but they seem to be offline. Craig Conley (the guy that runs it) sells on eBay under the name Mrpaxtonman. I'll see if I can dig up his phone number.
Your problem is either the output shaft seal or the output shaft itself. But, in my experiences, most of the SN series blowers always leak some tranny fluid into the intake. We had 3 SNs in the family at one time and all but one leaked. I also have the exploded drawing of the SN series. They are a little tricky to take apart, but once you can see it, there is nothing to it. And you have to take it apart to replace the seal.
Kevin
Kevin
Car: 92 Z28 Camaro
Thanks for the information. I took the blower unit off the car today, and after starting the engine, I noticed some oil in the air filter. My valve cover breathers join together and end up going into the filter to be ingested by the blower. I think the oil from the valve covers is working its way to the inlet of the blower. I do not like this set-up. I think I will just get some push in type valve cover breathers and be done with it. Anyway, I appreciate your help.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
The trans fuild is coming from the three lip seal price 60 dollars look at a
site called www. superchargerhelp.com go down to sn help.
toronto formula
Nov 10, 2015 06:17 AM
Forced_GTA
May 29, 2001 04:47 PM
89GTA5spd
May 21, 2001 05:55 PM
