NOS & manual Transmissions
Old Sep 18, 2006 | 03:27 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Here alot of bad things about using/combining nitrous with a manual trans equiped car. Any feed back on proper set up for street/strip racing? Launch techniques using nitrous, setup of progressive controllers etc.
my specs. are in my sig.
Old Sep 18, 2006 | 01:05 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
progressive controller just controls how much nitrous flow you get % wise at certain times then ups it so you keep traction and dont lose it. for a manual you want a window switch which will turn the nitrous on at a certain rpm and off at another rpm which should be right before your shift point. manufactures recommend activating nitrous at 3k rpms and above.
Old Sep 20, 2006 | 03:43 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
There's no issue if you can drive, alot of my friends are running nitrous on there 5 speed cars. A window switch or WOT switch is good insurance in the event of a missed shift, but i prefer the old handheld switch method. A B&M sidewinder shifter is a nice setup, but you could always just run some wires to a switch and hold it in your left hand. This way if you miss a gear you're not spraying unless you just really mess up. My moto for nitrous that's worked time and time again is to spray as soon as traction permits. I spray my car almots immediatly off the foot brake and the motor is at maybe 2200rpm. Get the tune right and make sure it's not way over rich and you'll be fine spraying.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
