n02
Old Oct 28, 2006 | 09:40 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
n02
ok another nitrous question.
I just bought a powershot nitrous system at a local swap meet. i was not going to instal nitrous because i don't know enough about it and not worry about my motor.
here is my question. i have a stock shortblock 350 with a better cam heads edelbrock intake and carb. headers and 3" exhust. I am wondering. they say that the kit i bought is factory setup for 125. will my motor pop with this or will i be ok. i would not use it all the time but once in a wile at the track. I just don't want to loose my motor.
also i have another block would just putting hypertonic pistons help with this power adder or do i need to have forged everything.
thanks for any info
Old Oct 31, 2006 | 05:43 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
As long as your motor is in good condition (not milage but health wise) I would say 125 shot will be perfectly fine. If you did decide to increase the shot you will definitly want to put a good set of forged pistons at the very least in there. Hypers and N20 are like walking on eggshells. They crack under alot of heat which is exactly what nitrous produces as well as a whole lot of increased cylinder pressure. I think if you just stick to that shot you will be fine. Strap on and have fun! Be sure to keep a close eye on your plugs and dont forget to pull some timing out of the motor before you spray just to be on the safe side.
Old Oct 31, 2006 | 06:11 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Hyper pistons are fine on nitrous as long as you have a loose enough ring gap. Forged are better because they're ductile, but they have to be ran loose because they expand alot. For a daily driver and a modest shot I'de stay with the hyper pistons just have them put a looser ring gap in. On your stock motor, a 125 shot should be cake, make sure your fuel supply's good by checking or replacing the pump and filter, take out 2 to 4 degrees of timing and run 1 stage colder plug and you'll never have a problem. Just do realize that nitrous is the crack of the automotive world, once you get one hit you'll want more and more and more
Old Oct 31, 2006 | 11:23 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
thanks for the info. i am running the stock tbi elec fuel pump with a mallory return style regulator. is there any way to test the fuel pump so i know how much i should have and how much i need? thanks again for the info. i was worried about 125 shot. people around here say that it is too big a shot. i just thought i would check with people who have more knowlege.
Old Nov 1, 2006 | 02:34 AM
I wouldn't run the stock TBI fuel pump with nitrous, it's probably taxed out the way it is. I'de upgrade to a larger low pressure in tank pump, or better yet sump the tank and run another type of high volume pump like a Holley blue, or a high volume block pump.
Old Nov 1, 2006 | 06:19 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
when i bought the no2 kit at a swap meet i got a holly inline pump with it. i cannot find a number on it but it does have 3/8" lines on it. i don't know if i could just put that inline and pull through the pump in the tank or if i should drop the tank and put a whole other sending unit in.
Old Nov 1, 2006 | 08:05 AM
It'll work either way. You'll get a little loss of flow because of the in tank pump but it'll still work and be alot safer than just using the TBI pump.
ProjectBird85
May 23, 2011 02:00 PM
Ronny
Jun 14, 2010 04:47 PM
grover85
Aug 5, 2008 12:14 AM
wingnut
Mid-West Region
Apr 19, 2004 04:18 PM
Blown WS6
Mar 13, 2002 09:24 PM
