Best turbo cam?
Old Dec 28, 2006 | 08:41 PM
$TransAm$'s Avatar
Best turbo cam?
What would be the best turbo cam to run on a small block chevy?
Old Dec 28, 2006 | 08:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
one that meets your requirements for power, compression, heads, intake, cubes, etc, etc
there is no one good cam. cam selection needs to be based on the rest of the motor from cubes, to heads, to type of intake manifold, to the turbo your using, and your power goals.
in general turbo cams are smaller in duration and have wider lobe angles. some feature more duration on the intake lobe
Old Dec 28, 2006 | 08:50 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
You should buy a catalog that will help you decide, it will let you know what to use per cubic inch and boost application, it will easily help you narrow the fields for easier selection, I hope you are not looking for a lopey cam sound, turbo cams do not often produce that effect, that is why they make good sleepers.
Old Dec 30, 2006 | 04:12 AM
83 Crossfire TA's Avatar
You should spend a lot of time reading and learning if you thought that was a reasonable question to ask…
There’s tons of info here on this board, in the related engine forums also.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
