vortech supercharger questions
Transmission: th350
can you use march pulley setups with the vortech kit for 88-92? i want to put the kit on my 87 but wondering if i can use a march pulley setup instead of having to use a stock setup from 88-92
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Yes and no. The supercharger bracket is going to relocate the PS pump and alt. The pulleys themselves won't make a differance. You can download the installation manual from vortech. It has the diagram for setting it up.
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Im 99% sure you cant use the crank pully.. Unless something has changed... Which basically renders the change useless... You can have the pullies MADE by ASP.. it costs more but they will make a 1 pc crank pully that will drive the blower as well..I had one of them a looonnnng time ago..
toronto formula
Nov 10, 2015 06:17 AM
