need info on turbo car fuel pump ?I have this one ....
Old Feb 7, 2007 | 03:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I was recomended to get the GCA758-2
" 255lph High Output 85-92 GM"
But I always see the GSS430 ( something liek that ) recomended on here. Whats the differance ? Is this one going to work ? It was called a pump for forced induction
Old Feb 9, 2007 | 10:37 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
this is a walbro pump aswell as the other mentioned .
Anyone ? I just don't want to find out the hard way I have the wrong one ...or a lesser desirable one .
Old Feb 9, 2007 | 03:27 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
That part number is the Walbro 255 lph high pressure unit. It flows the most out of the 255 lph pumps. In other words, you have a good fuel pump. It will flow more fuel than the regular one when used with an FMU. It will flow a little bit more all over in general.
Go to :http://www.autoperformanceengineering.com/
and click on the technical page for specs. Click on the kit page and you will see it is the GSS340 unit.
Old Feb 12, 2007 | 11:42 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
am I reading it right ...and this is just another partnumber for the GSS340 ? it compars all the specs to " 190 lph ..... 255 lph ... 255 HO lph" but it never gives the part numbers for which .
Just trying to find out what the differances between mine and the GSS430 is ...
K , I am not sure if I read it right but it seems... that the GSS340 is discontinued ...adn mine looks to be the new part number???/
Last edited by D's89IROCZ; Feb 12, 2007 at 11:47 AM. Reason: Automerged Doublepost
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
