nitrous fuel injector
Old Feb 16, 2007 | 04:14 PM
pairtoe's Avatar
is there such thing as a fuel injector that you can just hook up the nitrous right to it? instead of the nitrous nozzles. or am i not making any sense?
Old Feb 19, 2007 | 11:47 AM
fbodyguy86's Avatar
Car: 92 camaro rs
NOS makes them they are called NOSzles or something like that
Old Feb 21, 2007 | 01:15 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
yes, NOS makes them, they are little d-shaped cups that goes where the injector sits in the manifold and then the injector goes inside of that. This will ONLY work on aftermarked EFI setups, or ls1/ls6 set ups. There isnt enought clearace for the added height of the cup on tpi style engines and they dont fit the angle of the injector on a ls2 engine either. so its either the air intake nozzle, after TB plate system, or traditional direct port, and i dont think that it will work too well on the design of the TPI because of the sharp turns on the runners.
Old Feb 21, 2007 | 08:07 AM
pairtoe's Avatar
alright thanks, i just thought maybe some one maye a fule injector that that you could just hook the nitrous line right to. im just going to use a dry manifold system then.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
