Supercharger with 11.0:1 compression?
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
Just a thought for now.. But can I add a supercharger with 11.0:1compression? I have a 383 stroker with:
1) Dart Pro 1 heads 215cc/ 64cc
2) Accel DFI 7 with wideband o2
3) SRP forged 11.0:1 flattop pistons
4) Eagle I-beam rods
5) Eagle crank
6) cam motion cam
7) holley stealth ram intake
8) BBK twin 58mm throttle body
9) Accel 30# Injectors
I've seen the 93-97 F-body kits available from Procharger which are 4.5 PSI,
I had a 95 T/A which was 10.5:1 compression, If this can be done what gains should I expect?
5) Eagle crank
6) cam motion cam
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Supercharger with 11.0:1 compression?
to be honest, i wouldnt do it.. 11:1 is pushing pump gas as is.. if you run straight 110 then i would say hit up 7psi.. and gain 100+rwhp..
if you really want to boost, get the pro 1's with the 72 cc chamber..
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Here's what running 7lb of boost on a 10.5:1 motor did
http://videos.streetfire.net/video/2...ea017ce1ea.htm
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
sure it can be done, but its going to need some GOOD fuel!
Probably C16 minimum for a few pounds of boost, then maybe something stupid like C23 if you want to run more boost
I think your better off buying some larger chamber heads. then if your lucky you might get away with pump gas. For the cost of a drum or 2 of race fuel, you can buy new heads!
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
hey thats crackys car!!!!
i am going to run a 355 with about a 9-9.2:1 compression with a 3 core intercooler and kept the boost down to max 10psi.... i should be able to run 93 plus keep head gaskets......
but 11.1:1 is way to much!......
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Water/methanol spray injection cooling would help, however 11.0:1, still pushing it. Heck I know some guys go below 8.0:1 when they supercharge *L*
WhteRbt
Sep 21, 2015 09:48 AM
1051, 11, 1101, 111, 95, camaro, compression, cr, engine, good, max, motor, run, supercharge, supercharger, supercharging
