Finally got some juice!
Old Jun 14, 2007 | 03:25 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
I finally ordered a ZEX nitrous kit. They just released their EFI Perimeter Plate Nitrous System. I've been wanting to put one on my Pro-Ram intake for a while now, but I never did because the other Carb Perimeter Plate Nitrous System had a different fuel/nitrous jets due to the lower fuel pressure. When I saw the new kit on their web site I jumped on it. And it also made more sense to get a kit with just about everything you need. I am now an offical member of the NOS nation. Can't wait!
Old Jun 28, 2007 | 09:30 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Finally got some juice!
You should have better-even fuel nitrous distribution with your single plane intake than with the miniram. I run 1 step colder plug in the back 2 cylinders and 2 steps colder on the other cylinders. The back 2 cylinders(7-8) run the plugs black, and the front 2(1-2) run them white on motor and get tan on the bottle. You shouldn't have as bad a problem with your intake.
Old Jun 28, 2007 | 12:37 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
the perimeter plates are pretty awesome, though Zex solenoids kind of suck though. I hope everything works out for you though. Nitrous is addictive!!! dont forget the rest of you're safety stuff and accessories to make sure everything works to its potential!
Old Jun 28, 2007 | 06:03 PM
zz17iroc's Avatar
I installed it last week, but I haven't used yet. Why do the ZEX solenoids suck?
Rocket-Doc
Nov 14, 2015 02:08 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
JSDaddy189
Sep 26, 2015 03:50 PM
