Need good Blower cam
Old Jul 15, 2007 | 01:13 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I need a good blower cam for my camaro 5.7 0.30 over new afr 195 heads,the
cam i have now slp 502/510 lift,220/230 dur 112 lsa.the springs on my new afr are 600 lift.i need more power
Old Jul 16, 2007 | 01:17 AM
antoine's Avatar
Re: Need good Blower cam
good info,thanks guys
Old Jul 16, 2007 | 06:33 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
The cam you have listed should be an excelent shaft for 500-600 hp with 10-12psi boost. More lift wont really help ya that much, the blower is gonna force all the fuel/air in that it can reguardless of lift. A set of 1.6 rockers will give you .535/.544 lift and change the duration slightly. But that shaft should run like a demon.
Old Jul 16, 2007 | 09:16 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
more boost?
Old Jul 16, 2007 | 10:22 AM
antoine's Avatar
thanks i will use the slp cam.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
mhatfield 14
Aug 15, 2015 10:47 AM
cstrobel65
Aug 15, 2015 10:19 AM
