How to tell if you have a good blower cam installed?
Old Jul 23, 2007 | 03:50 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Is there any way to tell if you have a good cam for a supercharger installed? I know every engine is different and it takes some trial and error to find the great cam, but is there anything that you can look for?
I have an comp xr288hr with a 110 lsa. I've read that generally blown motors run well with a wider lsa, but some dont. I picked this cam because if it doesnt work out, I can use it in another engine.
8-10 lbs of boost
I'd like to do a before and after dyno (don't have the blower on yet) but it would take many pulls to get the timing and jetting perfect to set up the engine twice.
Is there another way? Vacuum reading? Egt?
Old Jul 24, 2007 | 01:29 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: How to tell if you have a good blower cam installed?
someting with a 112 lsa would work well with a blower, but this could work well, that cam seems to be a pretty good grind for nitrous use though. on a stock l98 with 200cc sportsman 2 heads, vic jr and 750 dp carb it made 406/385 on an engine dyno.
also on the home page there is a tech article about blower cams.
Old Jul 24, 2007 | 10:44 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I know what people say should be a good blower cam, but it isnt a fact. From what I understand, the exhaust side is the most important thing.
But how do you know without swapping the cam? Or is this the only way?
Those are pretty bad numbers for that big a head, and that big a cam......
I just saw the other day at the shop, a 383 with edelbrock rpm heads (170cc intake), same cam, make 470hp, 490 tq.
Old Jul 24, 2007 | 11:17 AM
Car: 91 z28
dont forget the l98 also only has 9:1 CR stock, this was with 76cc chambred heads so it could very well be in the 8's
Old Jul 24, 2007 | 11:46 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You're right, larger exhaust duration is the most important thing, well, along with a wider LSA to trap more mixture in the chamber.
One thing you can play with on the dyno, is rockers. Use 1.5 on both side, then quickly swap a set of 1.6 rockers onto the exhaust. That's a common mod to get more lift/duration out of the exhaust side, and supposedly is good for some power in a blown application.
Other then that, yea, swapping cams is how you find out if yours is best suited to your application
Old Jul 25, 2007 | 09:56 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Thats a good idea, I have 1.6 on it now, but I could throw some 1.5 that I have on the intake side. I guess if I dont notice any power drop, the exhaust isnt exhausting enough.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
anesthes
Mar 10, 2016 10:35 PM
camaro71633
Sep 1, 2015 10:24 AM
drathaar907
Aug 6, 2015 04:20 PM
