Fuel system NO2 question
Old Sep 16, 2007 | 01:57 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I have been looking and searching my so much my head wants to implode, I have got it down to a set up that i think might work for me. I am going to be running a Carbed 383 with a 200 shot.
What i was thinking was- run a big mechanical pump and a regulator for the motor, then running a small cell and an electric pump for the nitrous system. my questions are
Is this a good idea? running one mechanical and on electric?
If so, do i need a reg. for the nitrous too or just the motor?
What would be a good pump to use for both the motor and No2 system?
What reg. should i go with for one or both systems if needed.
Thanks for any help!
Colt
Old Sep 18, 2007 | 01:31 AM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
Re: Fuel system NO2 question
Anyone????
Old Sep 18, 2007 | 04:38 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
that could work just fine, just make sure, reguarless of the pump you get, you get a fuel pressure safety switch and put it as close to the solenoid as possible
yes, the fuel pressure will determine jet sizing , and generaly will be less fuel pressure than the motor runs on.
something that will flow enough for both, probably an Aeromotive eliminator or the Magnafuel Prostar 500 to be on the safe side
If you plan to street drive it, get a bypass regulator and run the return line back to the fuel tank/cell, that will be easier on the pump and will help fight vapor lock when in stoplight traffic. I recommend Aeromotive stuff for this as well, a 2 port bypass is all you should need.
I would recommend for a 200 shot to run a dedicated fuel system, you can get the 1 gallon RCI fuel cell from jegs/summit for $90 and then get the holley blue pump/regulator kit for $120, then just get the fuel lines to hook them up, you shouldnt need to run return style on the nitrous system, just have the pump turn on when the nitrous system is activated. Hope this helps
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
redmaroz
Aug 16, 2015 11:40 PM
