fresh lg4 rebuild.. 50-75 shot nitrous ok?
Old Sep 17, 2007 | 09:32 PM
Jammen Firebird's Avatar
I just rebuilt my engine and was wondering if a 50-75 DRY shot of nitrous would be SAFE!!! (plate system)
Engine specs
lg4 was already bored .30 over pistons and rods were in great shape
block was cleaned and honed
clevite 77 bearings
MOLY rings were put in
jegs hei dizzy
non cc q jet
stock alum intake.
open element air cleaner
Old Sep 18, 2007 | 10:36 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: fresh lg4 rebuild.. 50-75 shot nitrous ok?
Yeah, at that level it'd probably be safe, & quite possibly even a 100 shot - but nitrous has an unfortunate side-effect on people...
"Hey, that worked great! Let's go up just one jet size!"
As long as you can resist the temptation to go too high, I'd guess it should be fine.
BTW, you didn't mention what types of pistons were used (cast/hyper/forged) - that makes a big difference...
Old Sep 18, 2007 | 11:36 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Why would you rebuild an LG4 to spec?
"Boy, that 140hp was fun, lets rebuild it to enjoy that same 140HP all over again"
I thought most carbed plate systems are wet systems. I highly mistrust dry nitrous setups, too much to go wrong... I'd prefer a wet system myself. I think you're just fine with 75hp-100hp. If it were me, i'd sleep ok going up to a 125hp, but after that i'd be leery. I'd want larger ring gaps after that.
Old Sep 18, 2007 | 02:18 PM
just cast pistons. o btw i live at about 5300 ft elevation.
Also i forgot to add that i have a mellings cam 204/214
the heads were pulled apart cleaned and a 3 angle vavle job was done with new springs put in
Old Sep 18, 2007 | 02:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A dry system with a carb isn't really a good idea.
Old Sep 18, 2007 | 02:24 PM
ok so what if i went with a wet system? how much harder is it to make a wet system. just a small electric fuel pump off of the fuel line that goes to the mechenical pump
Old Sep 18, 2007 | 02:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
http://www.holley.com/07004NOS.asp
This is for Q-jet type spread-bore setups.
I am thinking about using this one in the future.
Only requires ~6psi from your mech pump.
EDIT
http://store.summitracing.com/partde...5&autoview=sku
$400. Damn, i'm on board! I think you can upgrade the solenoids to bring that up to a 200HP shot as well.
Old Sep 22, 2007 | 09:37 AM
so on the kit from holly will it work with the stock machnical fuel pump??? mine is brand new
Old Sep 22, 2007 | 12:58 PM
89redliningRS's Avatar
I believe they recommend an electric booster pump for the added pressure.
Old Oct 1, 2007 | 11:24 PM
well now what do i do...... I just bought a holly 650 carb and the adapter plate to hook it up to the q-jet manifold. so what would i get a plate system that goes between the carb and the spacer plate?
Pac J
May 17, 2020 10:44 AM
Mirror Image
Oct 29, 2017 09:51 PM
85cmroz28
Oct 4, 2015 09:44 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
JSDaddy189
Sep 26, 2015 03:50 PM
