Turbo Headers
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Turbo Headers
Happy new year to everyone!!
You all know that a couple of years ago we decided not to make any more headers because the company took another direction towards stainless steel product fabrication. We recently got a bigger warehouse in which we can accomodate stainless fabrication on one side and and carbon steel in the other. When carbon steel dust gets its way into the stainless steel is just a matter of time for the carbon steel to stain the stainless. Since our products are mainly for pharmaceuticals purposes it was risk we could not afford, being this the main reason we decided to not work on headers anymore. Well in other words we are going to offer our regular line of products again, except that for now is only going to be headers only.
Car: 91 Formula
Engine: L98 350 TPI
Transmission: TH700R4
Re: Turbo Headers
I have read through a bunch of the old posts but am still a little confused. Could you give an overview of what products you will be offering?
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: Turbo Headers
Just got my header today. When he says heavy duty he means HEAVY DUTY. The thing looks like its made out of roll cage material. I don't think this thing could crack this thing if I wanted to.
Car: 91 Camaro TBI 5.0
Re: Turbo Headers
Im interested in the turbo design you guys had for the 3.1l v6, are there any plans you can send to show how your headers look and how I need to route the piping? Im ready to buy the headers now.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Re: Turbo Headers
im interested in some headers for my 355...im in queens ny...all i need is the headers and you will probably need to kno which turbos i will be using so you can do the correct flange or do you have some sort of universal deal....pm me if you want or just reply here...but i am very interested....let me know...alex.
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
Sorry for not replying sooner. On Puerto Rico we have the official world's longest lasting Christmas/holidays season, starting on the Thanksgiving Day and ending 8 days after 6th of January.
Answering to the questions in order:
1) Headers offered will be;
Shipping charges not included; $35.00 for single turbo headers, $45.00 for twin turbo headers.
Ceramic coating available.
2)Timming; 1 week fabrication and 1 week delivery.
3)Website; not for now, but there will be with details, pictures and info.
Glad that you are happy with it.
The header can be used as a hammer, dead weight or deadly weapon(if you can swing it).
Please post pics of your setup, I'm always anxious to see how the new projects are going!
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
By the way I am looking for a NOS system or 1LE front brake system or Wilwood, Baer, whatever. Want to trade for a header? I will hear the offer.
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
The website is going to be up anytime soon. For now we will be offering headers only, including driver's side and crossover pipe for single turbo aplication.
Reputation7, PM for a deal on the nitrous.
By the way here is how my car looks like today, is customized, modified (except engine block and internals) and of course; turbocharged! Interested in nitrous also just to see how much the stock power plant can handle. Currently; 418 rwhp with 565 pounds of torque @ 16psi of boost and 116,000 miles on the clock and going
The car weights about 3100 pounds
Car: GTA
Axle/Gears: Stock
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Re: Turbo Headers
What size are the primaries? 1 5/8 or 1 3/4. Also can you provide the crossover tube? I am running a set of SLP shorties right now with 1 3/4 primaries. THis looks like a novel way to spend my incentive pay in march.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Turbo Headers
I think the header is built with weld-elbows. You are better off asking what size is the I.D. of the primaries and the log pipe.
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Re: Turbo Headers
What is the biggest downpipe that will fit with the V8 "V" Belt Single Turbo Header and a/c delete heater box?
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
The primaries ID are 1.375" dia. The crossover pipe is 2 1/2" dia. The biggest downpipe I had fit is 3" dia with A/C. I currently have a 3.5" downpipe which fits percfectly in my personal setup but I dont have A/C or even a 1LE A/C delete box, just an aluminum sheet metal.
Re: Turbo Headers
Im going to be buying the turbo header for the 3.1l v6 once my check clears on monday, 2/4/08, am I correct to assume that the setup uses the stock manifold on the drivers side, swings down under the oil pan, comes up into the passenger turbo header, and then into the turbo?
Car: 91 GTA
Engine: 377ci
Re: Turbo Headers
1.375, Holy cow! why so small? So does BBS offer both pasenger and driver's side headers. Has anyone tried using a mix and match?
Engine: 3xx ci tubo
Re: Turbo Headers
1.375" ID is typically what you will see on a 1 1/2" primary with 16 gauge wall. It takes a lot of work to use 1 1/2" weld-els (1.68" ID...same as 1 3/4" 16 gauge primaries). Half of the header building work goes into making the weld-el to header flange transition. That is why most people use the small weld-els.
Car: 91 GTA
Engine: 377ci
Re: Turbo Headers
Thanks for the response junkcltr. That makes sense, and if I understand you right, that header should be similar in dimenstion to my SLP's
As for the compressor question: "why only an AR of .60?" Anything bigger and you may run into fitment problems with the head, valve cover, and hood. At any rate an AR .60 can get you close to 500hp. That power level alone is enough to require making other changes to the car to ensure that it stays together.
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Re: Turbo Headers
ok well that's good to know since I'm already getting close to 500 now and I do have the supporting hardware to make more than that. I'm wanting to run a T76. I guess I'll just have to make my own like many others.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
The new website is bermudezcustomdesigns.com but is not up yet, anytime soon.
My Paypal address (email) is; bermudezbrainstormingdesigns@hotmail.com
I can be reached at (787)525-9482, please leave a message and I will call back.
Fax (787)760-9024
anesthes; I will seriously consider the C4 turbo/twin turbo project
Fax (787)760-9024
Re: Turbo Headers
Hi BBS! Few Simple Questions . . . .
Am I correct to assume that the setup uses the stock manifold on the drivers side, swings down under the oil pan, comes up into the passenger turbo header, and then into the turbo?
What are the diameters of the inlet and outlet piping?
Would you be able to create the setup without the external wastegate setup, I plan on using an internal wastegate, would it be cheaper on the price?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Turbo Headers
Good deal....
Fax (787)760-9024
Fax (787)760-9024
Re: Turbo Headers
Can you run fabricated aluminum valve covers with the single turbo v-belt setup? In all my research it looked like that the area between the stock cover and the turbo was really tight. If the tolerances are too tight for fabbed covers, could you perhaps put a small spacer/gasket combo between the header and turbo flanges to effectively "raise" the mounting of the turbo? Any help would be great 'cuz I already have the turbo header sitting in my garage!
It's a stout futhermucker too!
Re: Turbo Headers
Originally Posted by FerrMaro
In all my research it looked like that the area between the stock cover and the turbo was really tight....
Re: Turbo Headers
Fax (787)760-9024
Fax (787)760-9024
Re: Turbo Headers
Any ideas?
Similar to this, but all the way down the side of it for looks....
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
Slow, but comming
I am the "do it yourselfer" kind of guy and I barely had time this last couple of weeks to work on it.
Street Lethal; That is a very good idea with the valve cover! How is the whole projetc going?
Excellegions; I wrote you a PM a couple of days ago about the header, please reply.
I am the "do it yourselfer" kind of guy and I barely had time this last couple of weeks to work on it. Street Lethal; That is a very good idea with the valve cover! How is the whole projetc going?
Re: Turbo Headers
What is a PM!? What is it you need to know? I didn't get anything. You can post here, e-mail me at excellegions@hotmail.com, or call me at 954-326-6445, ask for Lee.
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Turbo Headers
one thing i was wondering was the flange on the headers that bolts to the head what kind of ports are on them? just wondering because there are many heads out there with different exhaust ports don't want to run into a bigger problem down the road i have GM fastburn heads.
Re: Turbo Headers
Car: GTA
Axle/Gears: Stock
Re: Turbo Headers
T76 is the largest I had installed in those headers. I attached a picture showing a T76 to the right and a 62-1 on the left, note the differences.
Street Lethal; keep us updated. Another thing, you must really love your 3rd gen. Because if it was me, I think I would forget it exist having a Z06 to play with instead
