ebay twin turbo kit
Old Jul 7, 2008 | 12:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
ebay twin turbo kit
Hey I saw this on ebay the other day and was wondering what everyone thought of it. The headers are the 304 which is supposed to be the cheaper material. they are t3 turbos so they don't put ou too much, but theres two.
Old Jul 7, 2008 | 12:30 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: ebay twin turbo kit
dont waste your money. You can build your own kit for almost the same price and use better parts.
Old Jul 7, 2008 | 01:17 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
A few people on this board have gone the ebay way and have been burned. The turbos break right away and are junk. Thats why they are so cheap. Save some extra money and do it right.
Old Jul 7, 2008 | 01:27 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I have built all of my headers so far using cast manifolds or all weld elbows (schedule 40 steel). One setup I played with was a single turbo T4 header kit from ebay. It is made of .050" wall stainless steel. The S/S is not magnetic, but I don't know if it is 304 grade. I think the left side tubular header, cross-over pipe, and right side T4 turbo header was $230 shipped. I removed the stock #2 cyl elbow and installed a 304 S/S schedule 40 elbow for strength. I also moved the wastegate pipe at the same time. I didn't like how it was attached to the cyl #2 pipe.
I had to cut and modify it to fit properly for my application. I have yet to put it into daily use. I also made a brace from the engine mech. fuel pump bolt holes up to the T4 flange.
Overall, I am neither pro or anti Ebay (really China) turbo stuff. Every product has it's intended application. If appropriately used in the right place then all will be fine.
Old Jul 7, 2008 | 04:43 PM
Tibo's Avatar
Car: 1991 Z28 Vert
http://cgi.ebay.com/ebaymotors/DUAL-...QQcmdZViewItem
Sorry, forgot the link.
Old Jul 7, 2008 | 10:59 PM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
Do you have a picture of the brace you made? I'm considering making one and I'm currently looking for ideas. Pics of your modded header would be good to see too.
Old Jul 8, 2008 | 09:32 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
make a brace for the headers or they will eventually give. for the price, its just fine and will work.
tonys91rs
Oct 10, 2015 03:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Ian Irvine
Sep 4, 2015 08:08 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
