Fuel pump for roots setup
Old Aug 16, 2008 | 12:22 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
I'm going to be putting a Weiand 142 on my 305. I picked up a Proform 750 carburetor for a good price to put on top. Right now I've got a mechanical 110gph fuel pump. Will this pump provide enough fuel, or will I have to switch to a 130gph pump and a regulator?
I know that I could use an electric helper pump back by the tank, but I don't feel like having gas pour in my face while I'm working upside down underneath the car
Old Aug 16, 2008 | 01:53 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Fuel pump for roots setup
Well, it's a good question and something I'm trying to find out myself. I doubt there's a accurate way to determine if it's too much, not enough or whatever. I plan to run a 130 GPH mechanical on mine with a regulator (already bought it) - I'm just hoping I don't end up returning too much fuel and overwhelming the puny 5/16" stock return line. If I do, then I'll end up dropping the tank and sumping it - trying to avoid it if I can...
Old Aug 16, 2008 | 05:15 PM
Car: '84 Camaro
yah I'm trying to avoid the sumping situation too. I was planning on using a non-return style regulator, probably an Aeromotive. Hopefully Damon will step in here and help out
Old Aug 16, 2008 | 09:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
110gph is about 660lb/hr and as long as you're only asking 5-8psi of fuel pressure from this pump it can fuel 1100fwhp/880rwhp. Carb. only motors are easy to fuel since they only need single digit pressures, not like me trying to run 80psi.
Old Aug 17, 2008 | 08:41 AM
Confuzed1's Avatar
Car: 83Z28 HO
Maybe you're thinking of electric fuel pumps? The 130 GPH rating on my mechanical pump is at 10 PSI....says it will support up to 800 HP. I believe the 110 GPH model is rated for 600 HP at 8 PSI....
phillip_helmet - Just for info purposes the instructions on my blower says the following: "The higher power output will require an aftermarket high-volume fuel pump such as Edelbrock #1711 (130 gal/hr), 1721 (110 gal/hr), 17000 (175 gal/hr), 1791 (120 gal/hr, electric), or 1792 (160 gal/hr, electric)".
- So I think your 110 GPH pump will feed your 305 just fine.
- Not trying to hijack your post (well not intentionally), I was mainly wondering if my 5/16" stock return line will handle the 130 GPH pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
evilstuie
Jan 9, 2020 08:29 PM
92camaroJoe
Aug 13, 2015 06:07 AM
