SBC Single Turbo Conversion Upgrade from SSAUTOCHROME
Old Sep 23, 2008 | 03:53 PM
91_GTA_TransAm's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: TPI 5.7L 350
Transmission: 700R4 4-speed Auto
I have been wanting to put a single turbo on my '91 Trans Am GTA for a while now and I ran across a single turbo upgrade kit from SSAUTOCHROME on Ebay. The kit looks very nice and it says that it fits all small block Chevys including the 283, 305, 325, 350, and 400. It seems like a good buy for $200. Is there anybody out there running this kit or do you maybe know of someone running this kit? I was just wondering if it would work on my '91 GTA and if it does work on my car, what kind of modifications would have to be made to install the turbo kit? My car has the 350 Tuned Port engine. Any information on this kit would be appreciated. Thanks.
Old Sep 24, 2008 | 02:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: SBC Single Turbo Conversion Upgrade from SSAUTOCHROME
do a search on here for ssautochrome. There's lots of horror stories about those paper thin manifolds cracking off.
There's a reason it's that cheap....
Old Sep 24, 2008 | 02:30 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You can take a look here for starters: https://www.thirdgen.org/forums/powe...bay-turbo.html
The wall thickness is .049" (18 gauge). The S/S pipe is non-magnetic. The flanges are 1/2" mild steel. I made a mild steel brace from the fuel pump bracket to the T4 flange.
I have not run this setup on an engine yet. Too much other stuff to do right now.
BTW, why have two threads asking the same question.......do you check both for answers?
Old Sep 25, 2008 | 02:52 PM
This kit is designed to put the turbo on the passenger side of the car isn't it? And I put two threads on here because I figure maybe different people look at the two different forums.
Old Sep 26, 2008 | 08:09 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Yeah, all kits put it on the pass. side because of the downpipe. Take a look at the pics.
Nah, you have two different threads in the power adder forum started by you with the same question.
Old Sep 26, 2008 | 01:00 PM
Just by looking under the hood of my GTA, it looks like a lot of modifications need to be made to put this kit on. What kind of modifications am I looking at here? My bad for having two of the same threads in this forum. I appologize.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
