where to run my pcv?
Old Sep 28, 2008 | 12:39 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
my f1 engine doesnt have an intake or air filter to the inlet of the procharger, where should i run my pcv valve tube? the other valve cover has an open breather.
thanks for any advice!
Old Sep 28, 2008 | 02:45 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: where to run my pcv?
You can get rid of it and add another breather.
Old Sep 30, 2008 | 10:39 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I run twin catch cans. Most forced induction stuff around where I live do the same thing.
Old Sep 30, 2008 | 11:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
explain?
Old Oct 1, 2008 | 12:17 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i run two edelbrock breathers one has a vacume line to the intake, the othe other has a a line to the procharger air filter. i dont have any issues now with oil blow by. the other way to do it is to have a catch can on each side of the engine or wherever u mount the catch can. just run a pcv line to each catch can a you will prevent blow by.
Old Oct 1, 2008 | 03:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
so a pcv on both valve covers to a shared catch or one pcv to a catch can and a breather on the other side?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
perZ
Aug 21, 2015 05:51 PM
mustangman65_79
Aug 8, 2015 12:07 PM
