roots blower questions
Old Oct 24, 2008 | 03:08 AM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
ok so i have my mind set on getting a blower to put on top of my motor after i rebuild it...and yes im rebuilding it for a blower...main question and sorta a favor is guys out there running say the 142-144 and 177 could u guys measure from your bottom of the intake to the top of your air cleaner and tell me what kind of air cleaner like thickness and car you are running...i have a jongbloed hood...curious to know if it will fit without cutting a hole on top of the hood...i think it might fit just might have to rig up a custom aircleaner inside the hood and find a way for the tubbing to connect and disconnect as your raise and lower the hood...but if a regular drop style aircleaner will work that be awesome...so if you guys could messure from where your intake meets the block to the top of your air cleaner and give me the details of what carb size aircleaner and kind it is be great...that way i can go messure it and find out if it will fit...also curious did you guys stick with your stock fuel lines or switch them out for bigger ones??? would be great to know what kind of power numbers you guys are putting out... anyways i forgot to mention its a gen 1 350 block...from gm goodrench...planning on either going with a 355 or 383 with the blower on it...just trying to make a fun street car...also was curious how loud is the whine...i want the whine lol...i only drive the car when its nice out...so im not worried about it bugging me...now right now i do have the stock rear axle with no posi and believe me i am going to see to that first before rebuilding the motor...i alrdy have a tremec tko 600 trans only has about 5000 miles on it...so not to worried about that...mainly i need to get a stronger rear axle and some bigger meats with posi...i know ill still be breaking them loose but thats fine with me...lol...anyways id appriciate your guys help and opinions and if you have questions to ask me fire away...
thx
Joe
Old Jan 9, 2009 | 05:41 PM
slow84 Z's Avatar
Car: 84-Z28
Engine: nitrous fed 383 SBC
Transmission: turbo 400
Axle/Gears: 9" 3.70 gear
Re: roots blower questions
joe/outlaw28 i own a 84Z28 with a 144cu. in. b&m mega blower. I just found your post today.measurements are as follows. from the bottom of the intake to the top of the blower 7 1/4" from the top of the blower to the top of the carb (holley 750 double pumper) were the air cleaner sits 3 1/4". I am using a 1 5/8 drop base with a 4" element. the top of the air cleaner is raised 11/16of an ". the total measure is 13 7/8". i have roughly a 4" bolt on cowl scoup. if you have any more questions pm me.
Old Apr 3, 2009 | 04:07 PM
blwn82z's Avatar
just found your post.i have the 177 with demon 750bc. you need at least a 6"cowl hood to run a air filter.i have a 4"with blower hat sticking out the hood.they do make a low profile 144 at weiand that the say fits under the hood.
Old Apr 4, 2009 | 05:58 AM
Damon's Avatar
Yeah, even the littlest blowers require a 4" cowl hood to run any reasonable sized air cleaner in a 3rd gen F-body. 177 sits the carb nearly 2" higher than that which means a 6" cowl hood is likely going to be required.
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
