NOS Sniper Kits
Old Nov 1, 2008 | 12:11 AM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
NOS Sniper Kits
Looking at this kit from summit
http://store.summitracing.com/partde...5&autoview=sku
Question is, would a stock TPI 305 w/ 107,000 miles be able to hold up to the 125 hp shot? Would it handle 150 if i decided to change the jets later?
A little info about my car. It has the 230hp/300tq TPI 305, dynaflow or magnaflow catback (can't remember right now lol), K&N Filter, some kind of aftermarket chip (was in it when i bought the car), coolant passage on throttle body is bypassed, smog pump and all lines have been removed, T5 with 3.45 posi 9 bolt, and a pretty good set of street tires. Has SFCs and a strut tower brace if it matters.
What should my car do in the 1/4 with that kit?
Old Nov 1, 2008 | 11:50 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Re: NOS Sniper Kits
It should shave a full second of your time, depending on when you're gonna spray it.
What tires are you going to use?
Hows the compression on your motor?
There isnt a 150 shot jet combo for a nozzle set up, & anything that high up on the jetting doesnt make it all the way to the back cylinders.
Old Nov 2, 2008 | 01:38 AM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Re: NOS Sniper Kits
I have Federal SS595 and I'm new to nitrous, when would be the best time to spray? I know i shouldn't spray right off the line since i am running a T5 and a 9 bolt and i wouldn't get any traction. I was thinking as soon as i shift to 2nd and when i shift to 3rd also
Also my base timing is 6* should i take a little out when i feel like playing with nitrous
Old Nov 2, 2008 | 02:50 PM
3rdBird's Avatar
Re: NOS Sniper Kits
I spray right off the line! Theres not enough time & too much to do after the light comes down.
Any motor will take 100+ shot & still hold up, remember to retard timing 2 degrees for every 50 hp.
Old Nov 2, 2008 | 02:56 PM
3rdBird's Avatar
Re: NOS Sniper Kits
BTW, the Sniper kit is a good, but very basic kit. The solenoids are smaller than normal, & you will need a purge solenoid kit, bottle heater, & blow off tube to vent outside of the vehicle. Plan on spending a grand to do it right.
Old Nov 6, 2008 | 01:52 PM
streetassasin's Avatar
Car: 2001 SS
Engine: bolt on LS1
Re: NOS Sniper Kits
^ thats why I buy used, I got my kit with a purge for $220 shipped, picked up a window switch for $85 shipped, got a bottle heater from a buddy for $50 and got a free blowdown tube and free bottle brackets
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
