Elc fuel pump for N02
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
I have a mechanical pump feeding the motor currently but Im getting the Edelbrock RPM kit soon and I doubt that pump will feed them both so Im looking for an electric pump for dedicated nitrous use and thats all. Going to start off with a 100shot and work my way up from there, the most being a 200 shot. Thanks in Advance.
Re: Elc fuel pump for N02
Yes I more than likely will..
u could always build urself something like this
this one has a just under 1 gallon capacity
i did this for my meth injection system but it could be used for a nitrous system fuel supply as well
the top later got a tube welded threw it that the hose from the fuel pump conected to and on the top of the lid it got a -6an fitting
the [ump was held on with 2 hose clamps with lil guids welded on the back of the aluminum bracket so the clamps couldnt slide up or down
oh yeah i almost forgot if u make something liek this use the screw on lid as the pump hanger and assembly it makes things so much easier
Thanks 89 but I cant weld, Im just gonna get a big electric pump to feed the engine and nitrous wen I want to use and Ill block off the mechanical pump mount and just sell it I gues..
And Joe thanks so much for your input! Really helped me out.. I have a Moser 12bolt I just dont use this site that much to update my sig cause of guys like you wasting my time.. If you dont have anything helpful to say dont say anything at all..
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
