IAT temp sensor location
Old Jan 9, 2009 | 08:34 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I am curious about where the IAT sensor should be located on a S/C engine. Vortech puts it in the Air Intake Tube before it goes into the S/C. I purchased a new Intake horn because I am installing a Intercooler kit. It makes more sense to me to install the IAT after the S/C but before the intake manifold so the computer can get a accurate reading of the air before it enters engine. Anyone have any ideas.
Old Jan 9, 2009 | 12:34 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: IAT temp sensor location
im leavin mine in the upper plenum when i put my motor together this way its showing actual temp in the manifold
Old Jan 9, 2009 | 02:37 PM
???'s Avatar
it makes sense to have it in front of the intake but after the intercooler. but it really is just matters what kinda FI your running. if your running a stand alone, then yes, if your running a code like the $8D. then there's a ton of things posted about mat sensor placment. they have figured out what to change in the bin when you relocate it. if your running say $59. I don't think they have that done the same way. and while I have mine in the intake tube with 59, since I came from a standalone and now run 59. I'm thinking of going back to in the intake its self because I doing think the bin is handling it right. I believe it uses the mat for most of the temp offsets. because there's a coolent based table that isn't used. I feel it should be if your going to run the air temp sensor in the intake tube. because the air spends so much time in the intake on any kinda long runner set up. but you can only choose mat or the coolant table. not both. for air temp correction.
Old Jan 9, 2009 | 02:40 PM
ibmtech's Avatar
Car: 1987 IROC-Z
That is what I was thinking. Apparently Vortech doesn't think it is that important. I put a thermistor in the intake plenum and the temps were almost 190 degrees hotter than what they should be because of the compressed air. I think the ECM changes the fueling amount through the ECM based on intake temps, that is why I was trying to get the engine temps down to a more reasonable amount. And I have to move my IAT sensor to the intake plenum and not the Vortech intake cold air intake tube. I am running a 7749 with $59 on a TPIS M/R.
Old Jan 10, 2009 | 08:28 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
With boost you always want a sensor that responds to quick temperature changes. The stock TPI IAT is WAY TOO SLOW. You also want it to measure the most accurate temp. entering the head.
I install the IAT right before the throttle body usually. I also use a 1990 V6 MPFI IAT sensor. It responds quickly but is more fragile than the v8 TPI IAT.
Old Jan 11, 2009 | 12:42 AM
???'s Avatar
I'm like 90% sure the stock sy/ty used the same kinda mat sensor the tpi cars used. and with that $58/$59 is setup needing to know the mat not just the iat. the table for it to look at the coolant temp is not enabled. it would be best to see the air temp spike under boost and pull timing based on it but gotta keep in mind how the ecm/bin handles that info.
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
tonys91rs
Sep 2, 2015 07:07 PM
